ohm load???
pretty much was retarded and hopped on a great deal for a 15" l7... 2 ohms loool
cant wire it to two ohms, but it will work at 1 ohm...
how good is it to put an l7 at one ohm??? i may fight it and try to swap it out for a 4 ohm
but any good 1 ohm amps around 1000-1500 watts??? i'm looking into the hifonics BXi 1208D but i'm not to sure on how solid that amp will be???
once again i'm retarded, thanks
Yeah you are retarded.
Congrats.
I suggest buying a coloring book and crayons. Try to stay in the lines, and dont eat the crayons. And if you want to release your inner creativity, stray from the lines occasionally...
The ohm load won't effect the speaker, it doesn't care if it's 8 ohms, or 1 ohm.
So wiring your L7 to 1 ohm will not be any different than anything else.
Theres lots of good amps that do 1k-1500W at 1ohm, whats your budget?
The ohm load won't effect the speaker, it doesn't care if it's 8 ohms, or 1 ohm. So wiring your L7 to 1 ohm will not be any different than anything else.
thanks that's what i figured, like i knew to buy 4 ohm, blah blah, i bought the sub, went to buy a zx1000.1 and said oh shit haha
but i'm looking under $300 on the internet
also, one ohms generally rougher on your bat/alt??
I remember my freinds tellin me that paralleling VC's is bad for the peekaz. Sigh.
Nope. Parallel or series, once again, doesn't really matter to the sub. I'd prefer to run at 1 ohm anyways, so you can get the full potential of a QUALITY amp. Of course shitty amps won't be nearly as efficient, but something like the kicker 1000.1 would be a great amp for that sub!
a_steezy
Banned
a_steezy
Renooo
ultimate157
