Official RE Audio Caraudio.com/Soundillusions.net group buy.
XXX Series 6.5" Component Set
Designed to be the ultimate in sound quality. The XXX series utilizes the patented XBl^2 motor technology for extreme linearity and audio reproduction. With a ruler flat BL curve, the drivers specs remain constant over extreme excursions unlike other motor types. The XXX series is the ultimate in sonic performance and output at any price.
Setting the new standard for reference systems, the XXX series components bring sonic realism to a new level.
Features
12dB per octave crossover network, High grade non-inductive resistors, Compression circuit.
6.5" midbass driver, ultra low distortion design, Rubber surround, Foam core poly cone, Cast aluminum basket, FEA optimized motor structure, XBL^2 motor technology*, High linearity nomex spider, Extreme excursion (13mm linear one-way). Good for sealed boxes or vented boxes of 8 to 18 liters tuned below 40 Hz.
1" Silk dome tweeter, Powerful Neodymium motor, Swiveling flush mount design, 28mm diaphragm
power handling 150wrms.
Impedance 2ohm.
Efficiency 87dB
frequency range 30hz-22khz
RRP £500.00
RE Series 6.5" component set
Midbass driver is optimized with XBL^2 to reduce distortion. Keeping the Bl flat means more constant motor force at excursion, which means better tracking of large signal inputs. Key benefits, flatter BL, Low distortion, Low inductance, Low Moving mass.
Clarity, control, and absolute effortlessness, the RE series sets the stage for an incredible audiophile system.
Features
6.5" midbass driver, Rubber surround, Mica filled poly cone, pressed steel basket, FEA optimized high linearity motor design, XBL^2 motor technology*, nomex spider. 7mm Linear one way excursion.
3/4" Silk dome tweeter, Powerful Neodymium motor, Swiveling flush mount design.
Power handling 50wrms.
Impedance 4ohm.
Efficiency 91dB
frequency range 40hz-20khz
I'm the cut and paste KING //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Thank God for cut and paste function. //content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif
For you guys running stock woofers in your home audio, these "RE series" would be ideal replacements. They can be wired to 8 ohms per driver and they are a real efficient sub. Kind of like a dual voice coil JL-W0.
anybody got the specs on the XXX 6.5?
TeamPSI never did post all the specs on the first thread about them.....
They're
3 5/8 deep
150w rms
2ohm
and sexy as hell
I'm looking for more like the full T/S specs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He said if your order is over $100 (not $99.99, but $100), you'll receive 15% off any other RE products
yup, i think i'll be spending more than $100 on what I'm planning to go for. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hmm, hopefully can get together 94 bucks for a pair of re12s and port them. think they'll beat 2 12" older w3s sealed with 125 watts each.? im pretty sure from what ive read about them.
TeamPSI
Super Pimp VIP Member
TeamPSI
Pink Star Industries
Prowler573
