Hey guys, now I am down to 2 battery choices.. It is either Kinetik HC2400 or the Odyssey PC1750
I originally was going to buy a HC2400, but a member suggested me Odyssey since and now it got me hooked and now I am unsure which one to get..
Kinetik Specs:
AGM Technology
Sealed Non-Spillable Design
Mount In Any Position
Ultra Low ESR
More Plates For Stronger Energy Density
Higher Voltage Under Load
Tightly Packed Cells
Superior Heat & Vibration Resistance
Weight: 69 lbs.
Ah: 128
Amps: 2600
Dimensions: 13" x 6.7" x 8.5"
Odyssey specs:
Absorbent glass mat (AGM) technology
12V battery pure VRLA
BCI group 65 battery
Rugged construction
Tin plated brass SAE terminals
Can be mounted in any orientation. To meet group 65 specifications, battery must remain upright.
Suitcase lifting handle
US DOT and IATA certified non-spillable
Shipped fully charged - just install and go
Container and cover made from oil resistant plastic
11 13/16 x 7 1/4 x 7 7/16
60 pounds
Reserve capacity: 135 minutes on 25amps
Odyssey PC1750 will fit in my stock battery location with no problem at all.. It got 135 Ah rating.
Kintik HC2400 will not fit in my stock location but I can make it work pretty easy.. also it got 128 Ah
The size of both batteries are a bit different, Hc2400 got 2600 cranking amps while PC1750 got 1800 cranking amps..
not sure if cranking amps are important or not.. So which one is better for me? I mean I think the specs said it all, Odyssey got a better Ah rating and will git in my stock location.. that is pretty obvious that we have a winner here but for some reason, something is telling me to go with HC2400..
SO I want to see what you guys would go with if you guys were me..
Thanks!
(if you choose "other" then post what you would use here, I only have 12" in length, 8" in width, and 7" in height to play with in my stock battery location)
Kinetik Specs:
AGM Technology
Ultra Low ESR
Weight: 69 lbs.
Ah: 128
Amps: 2600
Odyssey specs:
Rugged construction
60 pounds
Thanks!
