Oddball Neo driver spec; bandpass box 4th order
Rawr-DQ
!!!!Vote Third Party!!!!
I calibrated and tested this neo oddball with a WT3 woofer tester; jacob or anyone knowledgeable; do these specs look alright; and to any bandpass enthusiast, does the box have any flaws I should be careful of falling into.
Driver Properties
Name: Neo 12" driver
Type: Standard one-way driver
Company: Sundown
No. of Drivers = 1
Dual voice coils = series
Fs = 35.66 Hz
Qms = 5.591
Vas = 1.429 cu.ft
Cms = 0.11 mm/N
Mms = 177.6 g
Rms = 7.257 kg/s
P-Dia = 10 in
Sd = 0.0507 sq.m
Qes = 1.855
Re = 3.634 ohms
Le = 4.268 mH
Z = 14.59 ohms
BL = 8.829 N/A
Qts = 1.393
no = 0.0943 %
1-W SPL = 81.84 dB
2.83-V SPL = 85.32 dB
Trying out a 4th order bandpass design
Box Properties
Name:
Type: Bandpass Single-Tuned Box
Shape: rectangle, Bandpass
with two chambers
Chamber 1 - lower-freq.
Vb = 6.368 cu.ft
Fb = 39.39 Hz
QL = 5.207
F3 = 27.99 Hz
Fill = heavy
Chamber 2 - upper-freq.
Vb = 2.176 cu.ft
Fb = 45.89 Hz
QL = 6.239
F3 = 70.23 Hz
Fill = none
No. of Vents = 2
Vent shape = round
Vent ends = no flush
Dv = 6 in
Lv = 30 in
The box, the second smaller chamber will house about 14" of the port, they're 6 diameter and 30" long
I did more testing; here are the SS wt3 program:
Test Lead Calibration
Test lead calibration with 1k ohm resistor
Series Free Air
Series Vas Cal
Parallel Free Air
Parallel Vas Cal
Rawr-DQ
Rawr-DQ
Fort Myers, FL Posts:____________31,337,666,999
Rawr-DQ
