Obsidian subwoofers.
MrFoca
Ok so I have changed my setup I want to run. Thinking just 1 18 now. I have the room that's not a issue. Been looking at these subs, I see the rms is 600. Is this true or will they take more safely ? Looking for info on some good 18's. I've ran DD before but looking at what else is out there and sounds good. I still have my old box I built years ago just little over 7 cubes net. With 60 sqin of port tuned at 32. Don't know if I could still use that with a new sub, if I have to remake another box that's fine. Sub is going to be powered by a CT 1400.1
They are cookie cutter subs but a proven design. Rms is a pointless spec to a point. You are not going to run a clamped 600 watt sine wave for 12 hours straight.
Well I ask cause I'll be putting more than the rms states. I've heard 1000 rms also. So that's what made me ask
I like my OA 15s the reason I went with OA is because if one of them blow its just 160$ to replace them so its not a big deal. Most people say they can do 700 - 900 daily but idk I'm running 250 to each sub right now.
Indeed. Better to have to much than not enough. Was looking at the SQ hdc3 18 again. Might have another one built.
---------- Post added at 08:49 AM ---------- Previous post was at 08:48 AM ----------
Yes the price point is nice. 18's are cheap enough if I tear one up.
They are always on back order. That's what you get when you buy from a small cookie cutter brand. You get what you pay for.
The soundqubed 8's that I bought were off & on backorder also. By all means if you can give some suggestions I'm all ears. I would like to try something new.
I built a t-line for a customer with two OA 10s running on a 1400.1 and they took the amp fine but I'm not sure I would run one of those subs on a 1400 without backing down on the amp. As for the Strato v2, they will take 1200-1500 watts with no problem but again, I'd back off on the 1400.1 if I was only running one.
MrFoca
MrFoca
MD
Electrodynamic
vegang
vegang
