not sure what amp to buy
butler239
Hey, i got 2 RF t1 15's and im going to buy an amp tonight. i can either get a Memphis MCD1500 1500rms for 300, or should i just get a hifonics BXi2607D 2600 rms for 300? i mean the hifonics has a ton more power it says but im just not sure because the Memphis sells for 670 on sonics, is it a more quality amp? if someone could give me some advice that would be great =]. heres the specs for the amps
Memphis
Amplifier Specifications
Amplifier Class D
Number of Channels 1 - Mono
RMS Power (4 ohms) 750 watts x 1 channel
RMS Power (2 ohms) 1500 watts x 1 channel
RMS Power (1 ohm) N/A
Bridged RMS Power N/A
Total RMS Power Output 1500 watts
Peak Power Output N/A
Total Peak Power Output N/A
Maximum Input Gauge Size 4
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged N/A
THD at Rated RMS Power 0.5%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 50 - 250 Hz
Subsonic Filter 20 - 50 Hz
Signal-to-Noise Ratio 90 dB
Channel Separation N/A
Bass Boost N/A
Bass/Gain Remote Optional (Accessory required and sold separately)
* Memphis 16-MCRG
Fan Cooled No
Fuse Rating 30A x 5
CEA-2006 Compliant No
Hifoincs
Amplifier Class D
RMS Power (4 ohms) 850 watts x 1 channel
RMS Power (2 ohms) 1700 watts x 1 channel
RMS Power (1 ohm) 2600 watts x 1 channel
Bridged RMS Power Not Bridgeable
Total RMS Power Output 2600 watts
Peak Power Output Not Specified
Maximum Input Gauge Size N/A
Minimum Impedance Unbridged 1 ohm
THD at Rated RMS Power .1%
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 - 35 Hz
Signal-to-Noise Ratio 95 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating N/A
Please help im noob //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
So you need 1200 rms at either 1ohm or 4ohm. Neither of those amps really fit the bill. An MB Quart 1500d would however. Its about 200$ and is better than the Hifonics, and closer to Memphis then some would expect
hm well that sucks, that memphis is real cool looking. So it would be a bad idea to wire to 2 ohm? if its a real bad idea, where can i get one of those MB Quart 1500d's? iv never heard of the brand
some info since you were considering Hifonics...MBQ is from the same parent company as Hifoncs (Maxxsonics), and MBQ is the best line from Maxxsonics
oh well i know the subs are wired 1 ohm already, they were pushed by a rf 1000db before i bought them. so looks like thats what i need to go for is 1 ohm. is 1 ohm good for daily use?
Sure. 4ohm would be optimal, but its harder to find that type of power at 4ohm.
However, you are going to need good electrical. I suggest at least quality 4 or 2ga power and ground, as well as Big 3 upgrade (its fairly easy, there is a sticky in the electrical forum)
ah well i have a cap, and i have a extra yellow top battery in my garage i was thinking about hooking up, can you hook up batterys in cars or does it need to be a power cell? an alternator really inst in my budget at the moment, would those 2 work ok for now?
butler239
butler239
reno nevada
duro78
