not happy with my FI SSD'S 12's not enough out put.
You just answered your own question. If you want little output, build a little sealed box which is apparently what you've done. Give them the correct amount of airspace ported and you will likely be satisfied...ported boxes (if designed and constructed properly) are more efficient.
DD has a great explanation of why ported boxes are better in most applications here:
http://www.ddaudio.com/dd/caraudio/enclosureInfo/portInfo.asp
and here:
http://www.ddaudio.com/dd/caraudio/enclosureInfo/enclosureInfo.asp
can i go any smaller then 4 cubes, and still get good output? i cant fit 4 cubes unless i try and do what darkfox did with his stang. i dont want to cut up my car tho, and there would be no room for the amps.
Here is a recent build for 2 12" L7's in a mustang like mine.........
well darkfox got 4.9 cubes, port is 5.5 x 11.25 tuned to 35Hz. in his mustang...... could someone help with a design for 4 cubes tuned to 33hz. W 35 X D 28 X H 14 that is max
mustanggt5330
mustanggt5330
chicago,IL
mustanggt5330
