Not Getting Any Rca Signal
ELMAPA818
I have 2 12" Type R's and a Power Acoustik amp pushing both of them. I have the system hooked up to the stock stereo. The problem is that everything works good the only thing is that happens is that when I yurn on the car, the amp and everything turns on but the subs dont bump. I have to go all the way to the trunk and disconnect both Rca's and connect them again. Once I do this, the subs turn on. When I first installed the system, everything worked good. I had no problems with the setup. What is causing this? how can I fix it? This happens everytime I turn on the stereo and im tired of having to go all the way to the trunk every time.
Sorry about the typing problem. I dont know what happened there. The stock stereo doesnt have rcas, there IS a converter. Could it be that my RCA's ****? I know they work because all i have to do is unplug them and plug them in again. What I dont get is that this problem just started happening not to long ago. //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
check you connection on the LOC (the converter). make sure that all the connections are solid and no crappy ones. if they are good, switch out your rca's for a nice pair. and if it still happens switch out the converter and see if that works. try those and get back to us
Well I swaped out the converter and got some better rcas. Still the problem presists. I can not find what the problem is. I went through the whole wiring system and made sure all the connections were good. Im getting tired of this sh**//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif. Its not the Rcas and its not the converter, what else could it be.
Thats what I didnt want!! What could it be in the amp? Do you think I could fix it or will I need a completely new amp? This amp is brand new, I've only had it for about 1 month.
I guess I could do that, but where would i send it and what would I tell them is wrong with it(what part needs to be replace?) I would rather fix it myself if I could.
possibly the grounds are gone in the rca part of the amp or the power input on the rca is gone w.e i just bought an amp on here from a buyer said it worked 100% but i got it and the rca's were broken. here is the thread. but open the amp and check your rca's in there
http://www.caraudio.com/forum/showthread.php?goto=newpost&t=293074
X2. And if its under warranty and the rca's in the amp are good just send it back in.
ELMAPA818
ELMAPA818
Los Angeles
Steven206Seattl
