Critter
sig is what i have i will have a total of 3 mtx blue thunder pro3200 in the near future and will have a total of 4 in a few months.
for those of you that don't know what those amps put out here are the specs
Blue Thunder PRO300X2 Specifications
RMS Power measured at 12.5 Volts DC:
150 watts x 2 into a 4 ohm load with less than 0.05% THD+N
300 watts x 2 into a 2 ohm load with less than 0.1% THD+N
600 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
200 watts x 2 into a 4 ohm load
375 watts x 2 into a 2 ohm load
750 watts bridged into a 4 ohm load
Signal to Noise Ratio
> or = 110dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover
Variable 40Hz to 175Hz
12-18dB/Octave
HP or LP configurable
Dimensions
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4 Wide Including IsoFeet (36.2cm)
for the time being how should i wire it to get the best sound with the 3 amps? i was thinking 1 amp bridged into a 4 ohm load for each 12w6 and 1 amp for the 2 component sets. bridged into each channel?
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover
12-18dB/Octave
Dimensions
