sammy5gs
Hey guys...
I just replaced the head unit in my 1997 Camry with a newer unit. However, my car's wiring harness/adapter did not match the newer head unit's housing, so I started splicing and dicing. It all seemed fairly easy (all of the wires were color coded correctly with each other).
So, I hooked up everything, plug the battery back in, and I get no joy. I get a light where the power button is, but nothing else. I am thinking I must have cross-wired something, recheck, and nada. After some manipulation, I think I have diagnosed the problem to be the yellow car wire (from battery).
When I plugged in the unit's ignition wire (red) with the car's red wire, and add the unit's yellow wire, I get power, and everything is working fine. However, nothing is stored/saved as it relates to presets when I turn the car off. Presets/Time/etc are all gone.
In my limited knowledge, I thought that was the purpose of the yellow car wire (memory/backup/alternate). I am thinking I am not getting any juice from the yellow wire. Also, from my limited knowledge of these things (this is only my 2nd time doing this), I would have thought the yellow wire would have traveled all the way to the battery, but I am not seeing it connected (don't even know where it is from the dash to the battery).
Needless to say, any guidance you can give me in this regard as to confirmation if I am on the right track, and what I can do to fix this would be greatly appreciated. Let me know. Thanks much!
