mpb
I recently installed a Clarion DB455MC deck in my car and am having a problem with low volume when on FM mode. I used a wiring adaptor specific to my vehicle and the everything went in fine. The unit appears to work normal except that I have to turn the volume knob almost to the maximum when on FM just to listen at a reasonable level. This doesn't happen when on CD, Music Catcher, or AM. When in those modes, volume levels are normal.
I thought it might be the antenna, because when I bought the unit I was told I needed to use an antenna adaptor to make it work with the factory antenna. But when I installed it, I found the antenna plugged into the unit with no adaptor necessary. I should say that I get great reception (i.e., no static or fading stations), but I don't get the "stereo" indicator on any station. I also thought that if the antenna connection was bad, I wouldn't get an AM signal, but I get normal volume when on AM.
In case it matters, the car is a 2005 Kia Sorento LX.
Any thoughts or suggestions would be much appreciated.
