Noob question about multiple runs
mgcauctions09
With 2 runs I would run 2 positive cables off the front battery, fuse both cables, then run both cables to the battery bank (fusing each cable again before it gets to batteries, then connect them to the batteries. now from the batteries I fuse both cables again (6 fuses wow!) and then how do I put both cables in one hole in the amp????
you don't....distro block at the back if your amp doesn't accommodate the wiring.
why run 2 runs from the rear batts to the amp?
mgcauctions09
mgcauctions09
alabama
dman4486
