derricklkennedy
Well i decided on my system.. i have a 2011 chrysler 300.. im planning on putting 1 or 2 jl 13w7.. i will probably start out with 1 13w7 and amp and add another 13 w7 and amp later.. which amp should i use hd1200/1 or the the slash v3 (i cant remeber the watts but its ????/1) i also plan on putting c5 6.5 in the front doors and the c5 coaxials in the rear doors... so my main question is if i have an amp to each woofer, an amp to the coaxials, components and tweeters would i need a high output alternator and battery? I remember reading something about the jl hd amps that they only pull 11 amps of the alternator... is this true? Thanks for the info and i know most people bash jl, but this thread is not about saving money or better spl or sq etc etc.. thank you in advance for your advice.
