Now name all the colors on the new clip in the exact same order. Then I can tell you what wire goes where as long as they are both the same clip with just different colors. They connect to the same pins in the same places on both clips.
Okay, here are the colors of the new harness in the same order and labeled as they are stamped on the wire:
Metra OEM radio wire harness 71-2003-1
24 PIN TOP ROW – LEFT TO RIGHT
ORANGE ---- DASH LIGHT ILLUMINATION
GREEN W/RED STRIPE ---- *
BLUE W/WHITE STRIPE --- AMP TURN ON (12V+)
RED W/BLACK STRIPE --- * (x2)
BLACK --- CHASSIS GROUND (12v-) *
WHITE W/RED STRIPE ---
GREEN W/WHITE STRIPE ---
BROWN --- MUTE
YELLOW – 12 VOLT BATTERY/CONSTANT (12V+) *
GREEN --- LEFT REAR POSITIVE (LR+) *
PALE GREEN – *
PINK – TEL MUTE
24 PIN BOTTOM ROW – LEFT TO RIGHT
PURPLE --- RIGHT REAR POSITIVE (RR+)
ORANGE --- DASH LIGHT ILLUMINATION
BLUE W/BLACK STRIPE – *
BLACK W/WHITE STRIPE --- AMPLIFIER GROUND
ORANGE W/BLACK STRIPE – DIMMER GROUND
WHITE W/BLUE STRIPE –
GREY W/RED STRIPE ---
BROWN --- MUTE
GREY --- RIGHT FRONT POSITIVE (RF+)
LIGHT BLUE ---
BLUE --- POWER ANTENNAE *
BLACK – CHASSIS GROUND (12v-) *
12 PIN TOP ROW – LEFT TO RIGHT
BLUE W/WHITE STRIPE – AMP TURN ON (12V+)
BLACK W/WHITE STRIPE – AMPLIFIER GROUND
12 PIN BOTTOM ROW – LEFT TO RIGHT
GREEN W/WHITE STRIPE –
GREEN W/BLACK STRIPE – LEFT REAR NEGATIVE (LR-)
BLACK – CHASSIS GROUND (12V-)
RED – 12VOLT IGNITION/SWITCHED (12V-) *
WHITE – LEFT FRONT POSITIVE (LF+)
PURPLE – RIGHT REAR POSITIVE (RR+)
