Noob cut out the internal harness...
for an 01. but see if its similar
Radio 12v
lt green/purple
at radio
Radio Ground black - at radio
Radio Ignition yellow/black + at radio
Radio Illumination red/black + at radio
Factory Amp Turn-on
Power Antenna
LF Speaker +/- org/lt grn-lt blu/wh at radio
RF Speaker +/- wht/lt grn - grn/org at radio
LR Speaker +/- tan/yel - gry/lt blu at radio
RR Speaker +/- org/red - brn/pnk at radio
Radio 12v
lt green/purple
at radio
Factory Amp Turn-on
Power Antenna
IM TELLING i know where u copied that from... UMMM UMMM
Wire Color Function / Connection
Yellow = 12 Volt Battery / Constant (12V+)
Red = 12 Volt Ignition / Switched (12V+)
Blue = Power Antenna
Blue/White = Remote Turn on (12V+)
Orange = Illumination / Dimmer
Black = Chassis Ground (12V-)
White = Left Front Positive (LF+)
White/Black = Left Front Negative (LF-)
Gray = Right Front Positive (RF+)
Gray/Black = Right Front Negative (RF-)
Green = Left Rear Positive (LR+)
Green/Black = Left Rear Negative (LR-)
Violet = Right Rear Positive (RR+)
Violet/Black = Right Rear Negative (RR-)
Wire Color Function / Connection Yellow = 12 Volt Battery / Constant (12V+)
thanks man,hope this is the one,Ill check it out this weekend
Ridinhi
Ridinhi
Winston-Salem, NC
96GTIVR6
