Noise Problem
Hellbound
Big Poppa
A kind of distorted sound comes from the sub which the wires run through. I have a big box with two 12" subs, with two (+ -) hook ups. Where ever I hook the wire on eather side from the mono amp the sub sounds like there is something moving inside, but if hook it up to the other hookup the sound comes from the other sub.
You need to make sure all your wiring is hooked up properly. Make sure the subs you are running are the correct ohm load for that amplifier you are using. What equipment are you running? It sounds to me like something is not wired correctly.
yeah, youve got a problem with your wiring it sounds like. OR there may be a problem with your channels. Check the wiring through tho. Do you have all good connectors and no free wire hanging around?
Hellbound
Big Poppa
Hellbound
ST LOUIS
soundcustom
