noise interfeirance
Chance89
CrAsHiNg *****
I"m getting a lot of rumbling in my subs when you switch tracks or when the rpm's increase. It started when I switched amps, I used to have a competion ag series amp hooked up the same way. But I switched to a kenwood 846 4 channel and have the 1st channels bridged and one sub off them, and the other two channels bridged and one sub off them. I'm thinking my rcas in the amp might be loose, I have the ground right beside the seat belt bolt and cleaned good. whats going on?
Are you using a HPF? or ar you running them full range?
Sounds like your rca's or you have the gain and bass boost up all the way.
I have the hpf filter's turned off on the amp and running them @ 50hz on my deck....gain is @ 3/4...is that the problem. In the manual it says I can get some sort of noise filter to put inline somwhere. Are those things any good?
thanx
Chance89
CrAsHiNg *****
Chance89
Alberta
Chance89
