noise coming through, help
FarrisAudio
ky
My speakers recently started popping, when i turn my lights on, blinkers on. I have my door speakers and subs wired powered by amps, not the cd player. If i have it turned up loud, it will do make the subs pop pretty violently.
I checked to see if something with the cd player wiring was wrong. I jumped the power wires to the amps input, to see if it was something from the ones in my dash, and it still did it. I then tried jumping the remote wire going into my sub amp to the + wire from my dash, and hooked my mp3 player to my amp. so there was no signal or remote wire coming from my cd player to the amp. It was just by itself, and it didn't pop at all. Could my cd player be messed up? or the wiring?
Someone also told me the ground on fords will cause an interference, but i grounded it to the chassis and it still dd it. im stumped. Any help is appreciated.
i hate these problems. when you give the amps a separate source and everything works fine but then you hook it up like it should and its all ****ed up.
cant give you much advice. if the mp3 plaayer in the amp works, could be the cd player. try sending signal to another amp from ur cd player.
ok. its a cheap cd player btw, a wal mart pioneer. deh2000mp i believe
lol if its that cheap, you might as well replace it for a new good one.
but i guess if you dont wana , or dont have the money, try testing each component indevidually.
also, try setting down your gains, maybe that could help
FarrisAudio
FarrisAudio
ky
robertoyoung08
Mike Mccabe
