No Wire Harness Fits!!!
wbstein
USA
I have gone through so many wire harnesses trying to find one to fit.
I have a 1997 Lincoln Continental appearantly with "Premium sound" which means it has a JBL system.
No wire harnesses available from local merchants will fit the plug that I need it to.
Where can I get a wire harness that will fit a '97 CONT with premium sound...
OR a wiring diagram so I can just cut the cables myself?
Man I am really tired of this project, and any help would be much appreciated. Thank you.
PS.
The wire harness from the car has 6 pins on top and 4 pins on bottom.
The wire harness adapter available has 4 pins on top, and 5 pins on bottom.
Metra 70-5601...You have to run that harness from the trunk (where the factory amp is located) to the front.
http://www.amazon.com/METRA-70-5601-FORD-1994-97-LUXURY-JBL-SYSTEM-HARNESS/dp/B0002BETAY/sr=1-76/qid=1157566312/ref=sr_1_76/002-0254548-8058431?ie=UTF8&s=electronics
Product Description
This innovative product for car radio installations allows the installer to wire an aftermarket radio into a car without cutting and splicing the factory radio harness. Ford 1994-97 with Luxury JBL radio system Allows the installation of aftermarket head unit in Ford's with the LUX system Turbowires™ have been color-coded using the aftermarket radio industry standard (E.I.A. Color Code). Features a high impact, OEM quality, ABS plastic molded connector for the perfect fit, while the new GXL wire provides more flexibility, power handling and heat resistance. The precision hand assembled terminals are pressure-inserted into the plug making it virtually impossible to pull a wire out. All top quality design features. A handy chart on the back of the package allows you to easily make all of the radio's wire connections.
This is the only place I could find a picture of it, Metraonline.com didnt even show a picture
wbstein
wbstein
USA
Shyne151
michigan born
    May 14, 2026
michigan born
    May 14, 2026
