No speaker Specs, how do you determine enclosure requirements?
Shirt looks good, glad it went to a good home.
As for the enclosure, I would think something around .3-.6 net should be just fine. Just tune real low for hone theater applications.
It went to a very good home, it's the first new shirt I have had in years. I am more thankful than you could imagine!
And a question, does the larger box (in a sealed application) mean the tuning goes lower? Is there a difference in the sound waves having to travel longer distances as opposed to using polyfil where the waves are slowed down?
If it came out of a small HT sub it was probably in a ported enclosure, you don't see many of them sealed. Not that you can't run it sealed.
Thats a keep_hope_alive question... Wish i could help..
When i get a chance I am gonna ask if it was in a ported enclosure and if he remembers the length of the port when he tore the enclosure apart. I am still thinking I will go with a sealed enclosure though. It'd be a lot less guessing
Just found out the old enclosure was ported, .66 cubic ft with a 2 inch aeroport 3"-4" inches long. This means the tuning was around 50 Hz. The speakers response is between 40-150 HZ. I think I am gonna try a sealed enclosure around .45 cubes.
Any other suggestions would be awesome!!
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
613
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
491
654
560
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
