no sound stock headunit or stock
corto
my car got stolen amonth ago and they took everything including the factory amp why idk.? lol so i go get a new factory amp put it in no sound. i took the factory headunit out put in a aftermarket cd player no sound.. so i just ran wires to the each of my door speekers. so i have sound.. i have power going to the back of my amp i tested that.. where else could this problem be?
it seems like i should deff have sound if i pull the factory amp out and the factory headunit and then put in a aftermarket or does the factory amp have to be connected and working for you to get sound or otherwise you have to run new wires? i cant think a fuse that would be blown? because i have like 3 diff wires back 2 the factory amp with power
info is a little confusing did you install the after market harnes correctly to factory wires have you hooked a loose speaker from one of your + - terminals on one channel of the after market head unit. You should have sound no prob as long as the head unit is wired correctly.
corto
corto
Flint, Michigan, United States
corto
