lightning2000
I've installed quite a few head units along with amps, subs, components, etc and have never had this problem. Unit just did not cut on one day after putting the face plate back on. Has worked great for a year and a half and just stopped working. I checked all fuses and connections and all are good. I even replaced all fuses just to make sure. I took the receiver and connected the 12 volt and acc wires to positive battery terminal and negative wire to neg terminal and the unit cuts on so I know I'm not getting power through to the head unit itself. I have not checked to see if it's not getting 12v or acc but will do tomorrow.
My question is. If it's not getting either/ or then what needs to be done since all fuses are fine? Harness looks good as well and have no issues with anything else in the car. The car is a 97 honda accord.
