Niche amplifiers
Hey I am chinese but I know what you mean I thought I've seen them in some magazines like when they show the competitions but never heard anything bout preformance. They are all silver with a lighted blue symbol in the middle with an internal cooling fan but that's all I know.so anybody know anything haven't found there website but they are a fairly new company they said so I'm not so sure.
Most of the "Bling" amplifiers with chrome and lights are junk amps. You're smart to ask in places like this. If nobody's heard of them, I'd stay away.
No offense meant to Chinese folk..
i saw a niche sub in one of my magazines, a british car one. the sub looked pretty beastly and possibly well made. but i dont know anything about them, also keep in mind the magazine also advertises like legacy so it bein in there is no indication of quality.
i found some of the specs at the place from a catalogue they had at the store could someone help tell me if this is a good amp i am a rookie:
Mosfet Power Supply
2 Ohm Stable/Class D 1 Ohm Stable
0-24dB Variable EQ at 42Hz/Dual Variable Bass EQ's on 4 Channel Amplifier
12dB/Oct Variable Matched Low Pass/High Pass Crossovers 30Hz-4kHz/Dual Variable Matched Low Pass/High Pass Crossovers on 4 Channel Amplifier
24dB/Oct Variable Subwoofer Crossover 10Hz-100Hz/Dual Variable Subwoofer Crossover on 4 Channel Amplifier
24dB/Oct Variable Subwoofer Crossover 35Hz-250Hz - Class D Only
24dB/Oct Variable Subsonic Filter 15Hz-50Hz-Class D Only
Variable RCA Output Crossover 30Hz-4kHz
Output Pass-Throughs
Signal to Noise Ratio> 92dB
Remote Bass Control
Circuit/Thermal/Overload Protection
Cooling Fan
Gold Plated Terminals
Engraved End Cats
Chassis Mounted Fuses
NA3000D Class D Monaural Amplifier
2400 Watts Maximum
1200 Watts RMS into 1 Ohm at
600 Watts RMS into 2 Ohms at
300 Watts RMS into 4 Ohms at
W.10.26"x H.2.2"xL14.96"
NA60.4C 4/3/2 Channel Bridgeable Amplifier
1200 Watts Maximum (300W x 4)
75 Watts RMS per Channel into 4 Ohms at
150 Watts RMS per Channel into 2 Ohms at
5th and 6th Phantom Channels for Powering Center Spearker and/ or Subwoofer
W. 10.26" x H. 2.2" x L. 17.32"
NA6000D Class D Monaural Amplifier
4800 Watts Maximum
2400 Watts RMS into 1 Ohm at
1200 Watts RMS into 2 Ohms at
600 Watts RMS into 4 Ohms at
W.10.26"x H.2.2"xL21.26"
Are these good and if so which wub would be better to power 2 10" L7s the NA6000D or NA3000D??
i finally found the website it is:
nicheaudiousa.com
If anyone can help me with if this is a good amplifier or not it would good greatly appreciated especially if you are using one right now. thank you in advance
I would prob stear clear of this brand....get something a little more well known and be safe as apposed to buying something off the wall.Ive been around car stereo for a while and ive never heard of this brand.All i can say is be safe with ur money.
j521baller3
j521baller3
Los Angeles, CA
j521baller3
