Nice way to two 8g into One Terminal?
  • 4
Ramrod
Ozark, Mo
I have searched a lot and searching terms like 8g and terminal. Just brings up to much.
Trying to figure a Nice looking way to Stick 2x 8g Wire into 1 Subwoofer Terminal. Right now I have them trimmed down..
choke up on one wire, make a cut then Join/solder wires together. Then use a heat shrink to cover it. Then you only need to fit in one 8 gauge wire to the terminal.
kinda like this (doesnt need to be choked up that far)
Thx Jeff
I thought of that too. Right now that's what I'll end up doing.
I though about buying a short piece of Brass Solid Rod and making my own dual terminals.
Has anyone used Machined adapters pieces? I'm sure someone has?
Thx JeffI thought of that too. Right now that's what I'll end up doing.
If you want to use the money then here. I use toolmaker dual 1/0 to single 1/0 inputs for my amp, makes things connect a lot easier, Not sure how they will stay on subwoofer push pin terminals though.
Toolmaker Dual 8ga Speaker Output Blocks - Xplicit Audio
Or fit two of them in a 4 gauge reducer
http://xplicitaudio.com/toolmaker-4ga-to-8ga-reducer-pair/
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
Ramrod
Ramrod
Ozark, Mo
trumpet
Decebal
    Jun 10, 2024
