Got this off a member on diy,looks and sounds great!Going another route,again..
Does include the knob/cord.One of the nicest sounding amps I've owned.
Asking 300 plus ship.
ULTIMATE series A5, a three-channel amplifier rated at 2 x 85 Watts in stereo an 1 x 300 Watts in mono. In two ohm load it delivers 2 x 100 Watts in stereo and 1 x 500 Watts in mono. The mono channel is 1 ohm stable.
- Built-in fan control.
- Built-in, variable 50-125 Hz switchable high-pass filter and a 40 - 90 Hz low-pass filter for subwoofers.
- The sub channel is also equipped with a disconnectable 25 Hz subsonic filter.
The perfect amplifier for a good front system and one or more subwoofers in the trunk.
-Remote sub level control that includes phase shift control 0-180 degrees.
- RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Specifications
Number of channels 3
Amplifier class AB
Damping factor > 200
Mono bridge mode 4 ohm N/A
S/N ratio, A-weighted >100 dB
Output power in 4 ohm 2 x 85 W
Output power in 2 ohm 2 x 100 W
Mono sub channel 4 ohm 300 W
Mono sub channel 2 ohm 500 W
Input impedance, high level N/A
Mono sub channel output in 1 ohm 780 W
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,2 - 7 V
Input impedance >10 kohm
Filters channel A & B HP: 50-150 Hz
Filter sub channel LP: 40-90 Hz, Subsonic 25 Hz / 18 dB
Low level output No
Remote bass level control Yes
High level input with auto start No
Remote phase shift control Yes
External cooling fan terminal Yes
Phase control for subwoofers 0-180 degrees
Power consumption (idle) 0,5 A
Power consumption (max) 90 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 3 x 30 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 5,9 kg ( 13 lb)
Specifications
Amplifier class AB
Low level output No
Fuses 3 x 30 A
