Nice amp for 1 4ohm SVC 15' Around $300. Suggestions?
Look in the classfieds, there were tantrum 1200.1's in there......youll get about 1400 at 2-4 ohms, so it would be a nice amp for future upgrades, too.
Reason I'm going this route is I have 2 of the 15's. Looking to go active in a extended cab truck, so Ill only need the one set of speakers for the front, and 1 15. Makes sense though. That Orion I mentioned above is a 2 channel. Most of the mono amps I've seen put out insane amounts at 1 ohm, but not much @4.
The tantrum will do the same power at 2-4. Or you can get a Xenon that will do the same power at 1-4. The JL amps also do the same power at different ohm loads, but I think they are only stable down to 1.5
PollyCranopolis
Bees!
PollyCranopolis
Frostburg, MD
zachzchw
