C2C3PO
Hello !
Guys, my head is gonna explode if I try and search this anymore.....
I have been given so much conflicting advice from friends/coworkers, etc that I thought I better turn to knowledgeable people for the definitive answer. Here's my question:
I'm trying to upgrade the audio in an old muscle car without cutting holes,etc. This really limits me to using small plate speakers in the existing dash location (2 speakers) and the kick panels (2 speakers). I am then running a pair of 6X9 speakers in the rear, and a Kicker Hideaway Sub to provide some much needed bass.
The deck is a Pioneer unit that puts out 14 W RMS X 4 and I'm using a JL Audio 400 W four channel amp to power the speakers.
The challenge I am having is trying to figure out a way to PROPERLY hook up the four FRONT plate speakers (Polk Audio MM461P) that are rated at 4 ohms and 50 W RMS to channels 1 & 2 on the amp.
I tried it by connecting the set of dash speakers directly to the head unit/deck and then running the other pair of speakers off of the amp (channels 1 & 2) but as expected I'm not getting much out of the dash speakers in the way of output. The rest of the speakers sound fine but is there a better way to wire all four plate speakers to get the best performance?
Please be forewarned...you'll need to walk me through the very basics in terms of how to properly make the connections as everything I've read on series, parallel and a combination of the two has me confused.
Thank you in advance..............!
Rick
Rick
