Newb ? about REM wire
Remote wire is used for turning on your external amplifier on with the Headunit. If your using 1-2 amplifiers this will work just fine. If later on you add additional amps your going to want to upgrade with a larger wire to a different source either an accessory input or a nother 12v line that is you can turn off and on with a switch.
sorry, i didn't want to say go out and buy a $52 set of snap-on crimpers like i got
shite...i went for the $15 easy strip/cut/crimp tool
i use mine everyday, cant have cheap tools that break, i would rather not, i used to use the channellock crimpers and also have a set of kleins journymen, i recommend the channellocks over the kleins, even though they are channellocks are cheaper priced
also use mine almost everyday...many times a day and i have had them for probably 5 years...no problems....inexpensive is not always cheap
the channellocks were $20 the kleins are $32
crimpers get dull eventually the better they are the less you have to sharpen them
personally i know i can strip and crimp 0gauge no problem with these
i really hope you mean heat shrink tubing
shrink wrap, we use that at work on our L-wrap machine. its the same exact thing as saran wrap just goes through a heat and shrinks. ill use that next time //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
What? Wouldn't you just have your remote wire trigger a relay to turn on multiple amps and processors and stuff? Why would you want to put a manual switch in when the remote can do it for you?
pitbull187
pitbull187
IN
timelessr1
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
