New toy to play with ...
Looks like one very well put together amp. What are the specs on that work of art?
And when are you hooking it up for a sq review? Like that amp a lot just from it's looks.
Specs/info and components used are listed below:
http://www.celestra.it/eng/products.html
Or for those that dont want to click..
Components
We decided to dedicate a separate page to list and to deepen with right importance, all the efforts we carried out to look for the best, the most reliable and the most expensive components nowadays existing on the suppliers world-wide market.
" No other Car Audio manufacturer has ever made widely use of these Top brand and Company in the electronic components category."
1. Class A input preamplifier fully made with Siliconix© jfets, only Wima© "MKP4" polypropilene capacitors on signal path and input wiring with Monster Cable© "Interlink 300MKII".
2. Voltage amplifier totally made with MIL-JAN grade full class A complementary bjts, with auto-regulation of thermal working point.
3. Output devices are IR© complementary mosfets, each capable of 180W and continuous 21A.
4. Capacitor bank close to output devices is ultra fast and low-ESR, capable of 42 Joule (VA210) of immediately available energy.
5. Output wiring speakers by Monster Cable© "OMC".
6. Power supply wholly built with Magnetics© MIL-GRADE ferrites, United Chemicon© low-ESR capacitors and IR© power mosfets each capable of continuous 110A.
7. 24K gold plated copper with high thickness tracks Printed Circuit Board (top grade FR4 material).
8. Thermal dissipation by internal cooling tunnels, integrated and thermoregulated fans.
9. Battery supply connectors are Anderson© "Powerpole 80A" for 0.0002 ohm max contact resistance.
10. Chassis made by CNC and Laser cut machines, hand brushed natural aluminum, fully inox screw bolts.
Technical Specs
Where it is not specified ratings are for both models:
CONTINUOUS OUTPUT NOMINAL POWER *:
[both ch. driven from 20 hz to 20 Khz; THD
*These power levels have been measured by very tight and severe Joule's law phisical effects, it is not possible to directly compare these values with other brand amps declared values.
VA210
2x 100Watt / 4ohm @10,5 Vbatt. 2x 200Watt / 2ohm @10,5 Vbatt. 2x 400Watt / 1ohm @11,5 Vbatt. 1x 400Watt / 4ohm (bridged) @ 10,5 Vbatt. 1x 800Watt / 2ohm (bridged) @ 11,5 Vbatt.
VA250
2x 50Watt / 4ohm @10,5 Vbatt. 2x 100Watt / 2ohm @11,5 Vbatt. 1x 200W / 4ohm (bridged) @ 11,5 Vbatt.
OUTPUT NOMINAL CURRENT [THD
VA210
22 Arms continuous 45 Arms (500mS peak)
VA250 12 Arms continuous 20 Arms (500mS peak)
THD: less than 0.1 % until 1° clipping [20 hz to 20 Khz]
FREQUENCY RESPONSE [-3Db]: at 8 hz and more than 400 Khz (at nominal power into 4 ohm)
INPUT IMPEDANCE: 10 Kohm
INPUT SENSITIVITY: max 300 mVrms; min 4 Vrms
STEREO SEPARATION: 80 Db at 1Khz
SIGNAL TO NOISE RATIO: > 120 Db "A" weighted
CURRENT CONSUMPTION [at 12 Vbatt]:
VA210 idle 4 ohm (stereo) 2 ohm (stereo) 4 ohm (bridged) 1 ohm (stereo) 2 ohm (bridged)
nominal power
2 A 32 A max 63 A max 63 A max 135 A max 135 A max
VA250 idle 4 ohm (stereo) 2 ohm (stereo) 4 ohm (bridged)
nominal power
1.2 A 17 A max 34 A max 34 A max
PROTECT AT:
* short on speakers outputs
* battery voltage
* battery voltage > 15 V
* thermal with proportional start of fans at 40° C, shutdown at 70° C
* fully muted at turn on and off
DIMENSIONS AND WEIGHTS:
VA210
480 x 295 x 66 mm 11.5 Kg
VA250 237 x 295 x 66 mm 4.5 Kg
Very soon actually. Im gonna pull out a few other various amps as well as donors from others and have a bit of a double blindfolded audition in the upcoming weeks.
WOW...
That is one hell of an amplifier.
It's nice to see an amp with actual speaker terminals and quick power disconnects. Nice touch.
What are the specs on that lovely lady?
You and me need to talk soon too. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Via phone though, me no like typing. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
6spdcoupe
tends to get a bit cranky
6spdcoupe
In the armpit of the US
joetama
