New towers. Final impedance questions??
havoc97
Building a new set of towers currently and have a few questions I can't seem to figure out about the impedance after the crossover.
Here is the setup:
ID CD1E Horns (4 ohms)
Focal 6.5 Mids (4 ohms)
Tang band w6-1139sg subs (4 ohms)
(Odd selection of equipment, but had it laying around and figured might as well use it up)
I was thinking of running a three way passive xover, and running a behringer A500 amplifier with these specs:
Output power (RMS, 1 kHz @ 1% THD): Stereo mode (both channels driven): 125 watts RMS x 2 @ 8 ohms, 185 watts RMS x 2 @ 4 ohms; Bridged mono: 375 watts RMS x 1 @ 8 ohms • Output power (peak power, 1 kHz): Stereo mode (both channels driven): 175 watts x 2 @ 8 ohms, 300 watts x 2 @ 4 ohms; Bridged mono: 600 watts x 1 @ 8 ohms • Weight: 18.5 lbs. • Dimensions: 4" H x 19" W x 10.85" D.
Question is, what will my final impedance that the amplifier sees once those speakers pass thru the crossover?
From what I understand the amp will see 4 ohms for each frequency range, but I'm not sure if that is right.
Here is a tower preview pic
it depends on the xo. You could have a short depending in the xo you build. (not likely, but it could happen.) You will most likely end up around 4 ohms. How are you designing the xo?
Here is the setup:
If I am looking at this right you are planning on using the horn on its side? you do know that horns have a controlled output pattern. So you will have to aim them right at you to hear them and they will reflect off the floor and ceiling. I really think you should rethink your design. Also what is your frequency response of the drivers? what is the efficiency for the drivers?
i saw the same thing. cant do that. buy a new waveguide from parts express that gives a 60x40 dispersion. 60deg is is horizontal or a spherical. note that the horn waveguide determines the lower frequency range for which the horn is controlling dispersion.
premade crossovers can work, but you don't want to use them. you want the mid to play a wider range, like 200Hz - 4kHz
havoc97
havoc97
MINNESOTA
keep_hope_alive
