New to forum, Need system tuning advice
  • 1
DownFire
Hello. I am having trouble adjusting my system since I got my new sub. The system is as follows.
2006 Impala
Front stage:
Stock Deck for now, Clarion EQS746 EQ.
ID CTX componets powered by an MRP-F300 bridged to two channels one for each side. Tweets are cut into the sail panels (It looks cool but I hate it's sound). Fully matted doors.
Rear stage: None
SUB:
P3 in a 1.25 cubic foot box made just for me. Double thick baffle and 3/4 in all the way around (box was ment for a W7 but I see they have just as good if not better subs out there so I wait). It is run with a Alpine MP-500 at 2ohms.
Problem is since I put the P3 in the quality has kinda fell apart. I had an Infinity perfect 12.1D which was a great woofer but I broke it being stupid so I picked up the P3. I wanted to have a louder sub and it is quite a bit louder for shure but it is not meshing well with my front stage. Crossover points are 80hz and up to the front stage and 90hz down for the sub. I don't regret buying the P3 because I like to rattle my eyeballs some but I believe it's not what I really need for SQ. So I would like some advice on anyway I can even the sound out and get some of the muddiness out of the system (maybe to big of an enclosure for the P3?) oh and the sub is sealed. I have an EQ but to get out the muddiness with the EQ I loose too much else. the muddiness seems to reside between 150 and 300 HZ. Thanks for any help you can give me.
10
944
Not a whole lot of action on that front here if you're interesting in antique collecting. The hoarders have been collecting for a long time now...
139
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
105
446
DownFire
DownFire
San Diego
DownFire
    May 12, 2024
Brendon Jenness
    May 11, 2024
