New System Install Problems
dan45hk
I'm having some problems... there is really bad alternator whine which gets worse with revving. The car is a '94 Vette and has 0 gauge power and ground wire coming directly from the battery to the amps in the back (Zapco 1000.4 for highs, JL 1000v2 for sub). The alternator whine problem has me stumped as everything in the system is hooked to a 0 gauge wire coming from the battery negative. I don't see how this can cause a ground loop as there is only one grounding point. Any suggestions? I dont get any whine with just the sub amp (JL 1000v2) hooked up, but it starts when the Zapco is hooked up (but I guess you can't hear whine through a sub or can you?).
1994
Avic Z1 Head unit
Zapco 1000.4 to Rainbow Germaniums front and rear (Symbilink)
JL 1000v2 to 12W7 (RCA)
Just checked something else, I unplugged everything from the head unit and only left the 2 Symbilink cables, with the car off and the headunit and Zapco amp on I get the whine which gets worse when you turn up the gains on the amp. Does this still point to the Pioneer as the problem?
dan45hk
dan45hk
usa
dan45hk
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
