New system for my 1999 Toyota 4runner
Connerliam
Tampa
I was looking into getting 2 SQ HDS215s in a 4th order or a single HDS315 ran on a D1200 SQ amp. I do NOT want to wall of anything, or remove back seats, if you'd like to suggest something, keep it in that price range and keep in mind me not wanting to remove my back seat. Open to any and all ideas. Thanks!
If it helps, here are my cargo specs (They're near the bottom of the page) :
1999 Toyota 4Runner Technical Specifications
2 15's in a 4th order will not fit just behind the back seats, you have about 8 Cubes total and that will completely fill up the cargo area.
This is the back of my 97, the battery takes about 6" out of the space the box could use, my box is 7.3 Cubes, you may be able to squeeze a little more space out of it with Aero ports.
It depends, I have spent a full 10hrs doing 2 amps, 8 speakers, 2 amp kits, radio, seat lift and subs. I also rerun wire to every driver. That...
129
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
609
16
703
Connerliam
Connerliam
Tampa
UnderFire
