New System Build!!
blackv62009
hazard
i just recently bought a 2006 cobalt ss s/c. The system that i plan on doing is an Audioque setup. My amp will be the AQ2200D, and the subs will be 2 AQ HDC3 12's. I love audioque products so i figured id do another system build with their products. Ill post pics up once i start recieving the products.
if you do that youre only going to be able to wire .5 or 2 ohms. so you wont be able to get the full 2200 watts out of her.
lol...im pretty pumped about this build..
Too bad no one else will be now that you have posted without pics... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
tisk tisk, this thread is doomed and shall forever be shunned.
SHUNNED!
16
For sub, I recommend going true infinite baffle. You get to keep just about all of your trunk space AND sound great doing it (if you do it right.)...
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
173
599
blackv62009
blackv62009
hazard
DNick454
    May 31, 2024
    May 24, 2024
