new project has commenced
alright i'll just use the values off ur site //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and thanks ess dub see //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that took me a while to decipher
if you want it clear try some polyurethane, some water based will keep it clear and wont turn yellow as quickly
if you need any help on finishing wood give me a should i work at an unfinished furniture store and have experience finishing.
FVCK, i emailed mr. reimer at creativesound and it is going to take another week to get here (2 weeks total) //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
but the wait makes it all the more worthwhile.
*licks lips* 10 watt non inductive 7 ohm resistors: check
too expensive dayton binding posts: check
jantzen 20 gauge 70 Mh inductors: check
dayton poly film mind u .33 uF capacitors: check
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
relax, i shall satisfy you tonight //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
(you knwo what i meant //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
for those of you who doubt that wet sanding does anything, i'm here to tell you that you will be amazed. i practiced the danish oil on a piece of brace sanding 220 to 320 to (wet sanding here on up) 400 to 600 to 800 to 1500 to 2000 then 0000 steelwool for a nice smooth as glass finish.
PV Audio
The Vision of Sound
PV Audio
Indy
PV Audio
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
