New Preamplifier?
I actually have done several amp swaps and like the Rotel the best vs. H||H V800, QSC Mx-1500a, QSC Series III 3500... On my old DM330i the H||H V800 sounded the best.
QSC Series III 3500 is;
* 48v low rail, 96v high rail
* grounded collector topology like RMX series [this is a strange design]
* 6 power transistors per channel
MX1500a is;
PLX3402 is;
* 80v low rail, 130v high rail [i measured my amp]
* classic AB output stage topology [class H power supply of course]
* 8 power transistors per channel
Bridged PLX3402 gives you 160v / 230v of clipping headoom [not counting amp
losses]. That's why I like these amps alot, plus the excellent heatsinks/wind tunnel cooling.
Somewhere buried on the pro audio forum, the PLX3402 is the devil when
driving high frequencies, I believe it registered 5kw in bridged mode on a
burst test. But for subwoofer application, it will do much much less as the
power supply design is the limiting factor.
Two of these amps in bridged mode is sweet to drive any demanding pair of loudspeakers.
Note: Don't bother with the new and more expensive PLX2, it's the same power stage. lol
Good luck trying to find information on the H||H V800...
Anyway, you really can't compare the Series III or the MX1500a with the PLX3402. The speakers I have are 200 Watts, and I have tested this, during normal listening I only use about 35-50 watts. So, the 700 Watts of the 3402 is a lot more power, IIRC the MX is 350ish Watts and the Series III is 300 Watts (H||H V800 200x2 at 8 ohms). The Series III is also dual monoral and has no fans... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The PLX Series is amazing and very powerful but I doubt it sounds any better than the older amps. The PLX2 might be the same power stage but it will run circles around the PLX. We have used both of them on different installs using Meyer and Community Loudspeakers...
It's normal to consume low power driving midrange and tweeters, the more important
variable is the clipping headroom and lower powered amplifiers have less.
If you are satisfied that the speakers are driven well and you aren't clipping your
amplifier, then ditch the quest for amplifier and start a new speaker quest vs. preamp quest.
The better sound will be percieved when you drive the amplifiers to their limits, ie
the older amps will clip much sooner than the PLX will so at higher listening levels,
the music is not squashed due to clipping the transients.
It's normal behavior to assume the next series is superior than the previous series,
it's human nature to assume the company made a big leap forward in the next generation
of product. This may be so in the computer upgrade world, but it may not be so in the
audio world. If you look at QSC schematics, they have a habit of recyling the designs across
many product lines.
For example, PL236 'touring amp' [PL2 family] was the reference design. From this design they spawned lesser models in the PL2 family and all they do is minor tweaks to get
less power.
PLX series is the same circuit board as the PL236 reference board, for the PLX they do the
same methodologies to offer lesser models but the common denominator across the board
is they have the 'dataport' circuits [DataPort for remote computer control or the addition of external DSP modules] missing from
the circuit board.
This is good from a business point of view. You make one PCB and you created two
product families and in each you spawn different models.
PLX2 from an electronics point of view is the same as PLX except the PLX2 has
a simple active crossover for easy biamping, relocation of switches and new chassis.
In other words, it's 99% the same as PLX except for the cosmetics. The performance
numbers will be the same. The only unknown variable right now is if they made a new
PCB for PLX2 or did they just install and add-on inside. The only amp that is a complete new design is the class D PL380.
... but.. Someone on this forum posted a pic of the older QSC HV amp and the guts look the same as the PLX, lol
so the PL2/PLX PCB thing might have been done prior to these two families of product, lol...
There is alot of comedy with Crown & QSC ........ and the uber Labs have their own comedy too....
joetama
The British Ear
joetama
Cincinnati, Ohio
joetama
