Sold NEW Pioneer PREMIER TS-W1207D2 DUAL 2OHM
d77543020
Rating: 87.5%
7 1 0
65.00 shipped * 89dB Sensitivity
* 400 Watts RMS power range
* 1200 Watts Peak Power handling
* Dual 2 ohm impedance
* 18Hz low frequency response
* 500Hz high frequency response
* Premier 12" Champion Series Subwoofer with 1200 Watts Max.
* IMPP with Aramid Fiber Cone
* Integrated Single Sided Silver Binding Posts
* Composite IMPP Cone using Interlaced Aramid Fiber Woofer Cone Material
* Cone Reinforcement Arcs Woofer Cone Design
* Wide Roll, Three-Layer Fiber Woven Radial Surround
* 4-Layer, Long Voice Coil
* Copper Voice Coil Wire
* Phenol Resin Coated Glass Cloth Voice Coil Bobbin
* Conex Damper (Spider)
* Damper Ring
* Standard Top Plate
* Projected Pole Yoke with Vented Pole
* Double Mass High-Power (83oz) Magnet Construction
* Stamped Basket Design with Magnet Cover
* Gasket Molded
* Integrated Single-Sided Silver Compression Terminal Wire
* Dimensions: 327 mm x 172 mm
* Mounting Depth: 153 mm
* Recommended Enclosure: 0.85 to 1.75 Cubic Feet 12 inch paypal only bought this sub by mistake i wanted dual 4 ohm so now i have to get rid of it
d77543020
d77543020
stockton ca
d77543020
