the twelve is like 16" deep IIRC
and you have to remember there are subs under this price that are in DIRECT competition to this sub... as far as top output...
to reach full excursion on something like this you'll need more than just a few kilowatts per sub
the reason is they have no way to keep MMs down and provide high power handling... so efficency suffers and they have to try and make up for it through BL...
you can tell from the motor size and height that you can expect around 30-40Tm of motor strength which means huge depth and motor size... also assume huge coils at least 4 layers...
to gain efficency you either increase motor strength or lower Mms.. .and motor strength only helps so much
if David wants something usable sealed (the only way you'll use this excursion PERIOD) he needs at least a QTS of .3... meaning that this thing is massively inefficent due to the extreme need for the high power handling which means... necessarily... and increase in Mms
don't get me wrong though...still a great sub.... might just want a Hifonics Goliath per XXX
