new kicker comp r's how to wire
Above the terminal there should be a switch. If yours are the dual 2 it will say 1 or 4 place them on 4 then parallel them to the amp that will give 2 ohm load. if it says 2 or 8 then you need to go 1 ohm if able or run tem at 4 unless you have a second amp then you can run each at 2 ohms.
cheapy
cheapy
Washington court house, ohio
tommydh
