new insane jl audio
only thing sean assisted me with is the parameters which would be the technical data that he states that he helped me with
I composed everything else myself, if you doubt my knowledge your more then welcome to come here to the 8" challenge in the beginning of january
why would you think otherwise?
I didn't say Warbleed is god ... I said JL listed 4 inches of peak-to-peak EXCURSION (NOT XMAX !) and that was about what Warbleed said it was ...
You said, "Where did the other 1.7" go ?" and I responded that it's capable of 4" peak-to-peak, it's just non-linear at 4" p-p ...
And at what point did I say that it would travel 4" peak-to-peak under normal circumstances ?
Someone woke up on the wrong side of the bed this morning ...
If you want to attack someone, attack JL for listing suspension capabilities instead of linear travel in their advertisement ...
If you cut the spiders loose on any sub it may move 4" peak to peak, but it wont do it during play, just like a W7. Mechanical excursion doesnt matter, because it will never perform at that level. In reality, they aren't capable of 4" unless your conditions are standing on the cone and pushing it up with loads of force.
What's the point of talking about how far past the xmax the W7's suspension can travel? It wont be linear. If so, we should start talking about all motor limited subs in this regard. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
In most installs, a suspension limited design (Brahma) or a motor limited design (W7) still needs to be compared with distortion being considered. Otherwise you are comparing apples and oranges.
That has been my point exactly. It doesn't matter what it can do in conditions that don't exist, if it wont do it in a car during play, it doesn't matter. Speakers are there to recreate an audio recording, not to look pretty or have fancy numbers attached to them. If it doesn't do it in the application, it doesnt matter.
(directed at ibeaner)
ooooooooh god
he was just tellinng u where the numbers came from....L-E-T I-T G-O
oh ndmustang i have think u are great person. I really like the install u did in that BUick (aleat that is what i think it was). I was gonna ask u for help with my custom setup and some stuff about customizing setups Like how in the hell do they hide the screws in an custom vinly trunk install??????
"When demanded by program material, the Gotham’s amplifier can deliver 3800 watts of RMS power to take full advantage of the twin drivers’ four inches of peak-to-peak excursion capability. This ensures that the Gotham can breeze through material that makes other subwoofers go into clipping, limiting or distress."
Where does it mention the motor will be grossly out of alignment, and the sub making something other than music, at anything close to 4"? Since when does marketing babble account for anything around here?
Again, you confuse Xmech with Xsus. You needn't cut any spiders off to make a W7 move that far. It has linear suspension travel that far, Xmech is a bit beyond that. Now obviously if we need to cut the spiders off a speaker to make it move 4", then that's far beyond Xmech, let alone Xsus. So, that's why your example is rather stupid.
You don't need to harm the W7 to make it move that far. You just need a low frequency and a decent amount of juice. Yet again you make a terrible comparison...
deagle44cmag
deagle44cmag
PA
deagle44cmag
