Item(s) for Sale
rs-d2200T
Item(s) Description/Condition:new
Premier PRS Series 2-Channel Full-Range Class D Car Amplifier
RMS Power Rating:
4 ohms: 150 watts x 2 chan.
2 ohms: 300 watts x 2 chan.
Bridged, 4 ohms: 600 watts x 1 chan.
Max power output: 600 watts x 2 chan.
PWM (Pulse Width Modulated) MOSFET power supply
Wired remote bass level control included
LED power indicator
Selectable Bass EQ (0,6,9,12 dB bass boost at 50 Hz)
Full-range Class-D ICEpower gives the amplifier incredible efficiency that enables it to put out tight bass with minimal lag effect as well as crystal clear mids and highs
Independent left and right channel circuitry gives this PRS amplifier a cleaner signal output as it maintains channel separation while eliminating signal interference
LT OP AMP (Linear Technology Operational Amplifier) prevents any sound quality deterioration
Energy saving design allows this PRS amplifier to draw less draw from your vehicle's alternator, giving you improved gas mileage
Full custom-made power supply capacitor bank
Compact design
Speaker-level inputs with included high-level to RCA adapter
Preamp RCA outputs
Compression-type speaker terminals
Balanced isolator input circuit
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (40-500 Hz, 12 dB/octave)
Variable low-pass filter (40-500 Hz, 12 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 10-50000 Hz
Dimensions: 12"L x 8-3/8"W x 2-1/4"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Price:200
Item Pictures: View attachment 26527274View attachment 26527275View attachment 26527276View attachment 26527277
RMS Power Rating:
LED power indicator
Compact design
Preamp RCA outputs
Price:200
