New Head Unit has a crossover setting that I don't understand?? db?
eb2phkingood
ok, i get the typically hpf of say 120hz. but my new hu kdc-x794 not only says 120hz but then below it i can choose from -3db, -6, -12, -18. is this just all personal taste?
standard starting points for lpf on a sub amp are generally about 80hz, while hpf on a speaker amp is usually 100hz sometimes 120hz.
what are the standard starting points for the db on a hpf and lpf?
Hey nice Head Unit, just installed one myself and its nice
crossovers have slopes, basically a crossover is not all or nothing. Normal slopes are -6db, -12db and some use -24db. Basically at the point you select, let say 80HZ for a LPF on the sub. So at 80hz if you set -18db it would be pretty quiet(less content allowed) above 80hz. Now if you used -3db you would still have a lot comming through at 100hz.
Basically most use this to "blend" a sub in with the front statge. You can try running a higher LPF with a sharper cutoff(like -18db, so 80hz) or some find it better using a lower cutoff with a lesser slope(like 50hz, -6db). I suggest playing with the 2 setting mentioned here and see which you like best
Normally -12dp is standard 1st step for passive x-overs for component sets, but its all in design and how things sound/blend.
Its more technical than that, but -6db is 1st order, -12 is 2nd order, ect..(every 6db)
eb2phkingood
eb2phkingood
kansas
whitedragon551
