New CDT 3 way Components
wanderer1
Item(s) for Sale: Pair of EU-6Woofers. Pair of HD-3 Mid. Pair of TW-25 silk dome neo Tweeter. Pair of EX30 3 way X-Overs
Item(s) Description/Condition: EU-6 New with grills 10/10 norm 6.5” cast mid woofer
Technical specs and contents: Woofers Etc.com $159 •Cone: Coated Carbon Reinforced Paper
•Diameter: 6.5" (170mm)
•Sensitivity: 81.65 dB
•Power Handling: 70W RMS (100W Peak)
•Frequency Response: 40 - 1000 Hz
•Nominal Impedance: 4 Ohms
•Voice Coil Diameter: 1.0" (26mm)
•Peak Xmax: 5mm
•Magnet Weight: 20 oz
•Mounting Depth: 2.63" (66.8mm)
•Cutout Diameter: 5.78" (147mm)
•Outer Diameter: 6.63" (168mm
•Free Air Resonance: 43.07 Hz
•Voice Coil DC Resistance: 3.27 Ohms
•Voice Coil Inductance @ 1 kHz: 0.25 mH
•Mechanical Q (Qms): 5.67
•Electrical Q (Qes): 0.937
•Total Q (Qts): 0.804
•Compliance Volume (Vas): 11.1l; 0.392 cu ft
•Moving mass, Diaphragm: 30 Gr
•Motor Force Factor: 5.32Tm
HD-3 - CDT Audio HD Series 3" Midrange Drivers $119 Plus $30 for grills. •Diameter: 3.0 (76mm)
•Sensitivity: 84.9dB
•Power Handling: 30WRMS (50W Pk)
•Frequency Response: 115 ~ 11,000 Hz
•Voice Coil Diameter: 0.8 (20mm)
•Peak Xmax: 5mm
•Magnet Weight: 7.2 Oz
•Surround Rubber
•Frame Cast
•Cone Paper
•Mounting depth: 1.69 (43mm)
•Cutout diameter: 2.90 (73.7mm)
•Outer diameter: 3.70 (94mm)
Decorative Bezel is 4.125
diameter and 0.625 deep
with four 0.175 diameter
mounting holes on 3.375
diameter mounting circle
Thiele-Small Parameters
•Free Air Resonance: 115 Hz
•Voice Coil DC Resistance: 3.1 ohms
•Voice Coil Inductance @ 1 kHz: 0.11 mH
•Mechanical Q (Qms): 2.42
•Electrical Q (Qes): 0.729
•Total Q (Qts): 0.560
•Compliance Volume (Vas): 0.97; 0.034 ft3
•Moving mass, Diaphragm: 3.25 Gr
•Motor Force Factor: 3.16 Tm
TW-25 New 10/10 •1pr 1” silk dome tweeter driver neo charged magnet structure
•1 pr flush mount housing w/hardware
•1 pr angled flush mount ring
•1 pr flat surface mount cup
•1 pr angled surface mount cup
•Cooled by ferro fluid
•Frequency response 1500Hz-20.000Hz
•Impedance 4 Ohm
•Sensitivity: 92.5dB
•Surface and flush mount mounts
•Flush mount hole 1 ¾”
•Flush mount depth ¾”
•Flush cup OD 2 ¼”
EX-30 New $199 10/10 you should read about it on the CDT site •Mid-woofer EQ adjustable
•Tweeter EQ adjustable
•Built-in tweeter protection
Price: $525
$15 for shipping
Awesome sound from high end components built by people that want you to have an enjoyable car audio experience. If ya want to throw some power at them and they will bang loud but clear. The motor of the HD-3 barely clears the cutout hole for the driver.
Got more CL-6Ms and EU 6s. Swap to the CL-6 for more midbass, EU 6 for SQ $500either one, or stay with the CL-61 for a decent driver at a really low price. Will also trade for a Zapco1100.1 Reference DC. RTS
wanderer1
wanderer1
Laughlin
wanderer1
