new b who needs help
mike75356
If i where to get a set of boston acoustics pro 6.5" componet set. And i have two places to put 6x9's i my car. Would i be able to get two of these adapter plates http://www.crutchfield.com/S-OxfeW4cL7HZ/cgi-bin/ProdView.asp?g=103200&I=142SA69.................. and be able set up the whole componet set ? Like would there be something else i would still need to mount somewhere? My problem is i have an older car that i dont wanna drill into or make any holes in the door or anywhere else.
thanks
mike
ok are the crossover wires regular speaker wire that i could run like down and set the crossovers down on the floor in the trunk ? and like i was lookin at the boston acoustics pro 6.5"http://www.boostcaraudio.com/Boston_Acoustics_Pro_6_5_p/pro%206.5.htm
And i could use that plate i showed you and the tweeter and everything would be mounted in there right? Like there would be a place for everything except the crossover?
ok are the crossover wires regular speaker wire that i could run like down and set the crossovers down on the floor in the trunk ? and like i was lookin at the boston acoustics pro 6.5"http://www.boostcaraudio.com/Boston_Acoustics_Pro_6_5_p/pro%206.5.htmAnd i could use that plate i showed you and the tweeter and everything would be mounted in there right? Like there would be a place for everything except the crossover?
fyi, crutchfield, while great with ther products n packaging n what not (they give u guides n extra cables n accesories) charge you like a b****, if u want them boston pro's (Im lookin into getting em, tht or diamonds) then ur gonna want an amp, comps are power hungry and u gotta send em some good clean power (skrew headunits), tht outta the way, i guess u could duct the xovers, and who knows what to do with ur speakers, if they fit, cool, if not....caulk and more duct tape?
mike75356
mike75356
pittsburgh
Mooseaudiophile
Mike Mccabe
