goualee
Been doing some moderate research here and there and got my setup in.
2012 Infiniti qx56
Stock head unit
Sundown audio scv-3000d amp
2 ohm 15" Sundown audio zv4 rev.2
4.25 cubic feet enclosure 32hz from customboxman
Knukonceptz kolossus fleks 1/0 cable
Big 3 upgrade with 250 amp fuse
Stinger rca cables and 10g speaker wires
2 ohm subwoofer wired parallel to 1 ohm. Not sure if stable. High to low line out converter is tap to rear factory subwoofer. Not sure high to low converter necessary if hooking to factory subwoofer. Not sure if hooking before amplifier makes a difference but don't know where it is. Gain set to 50-75%. Bass on head unit is 0. Settings on amp (estimated) : gain= 75% subsonic= 20hz bass boost= 2db lpf= 100 hz phase= 0°. Music played with engine on. Stock alternator says 150 amp on it. 14.2v-14.8v at amp with voltmeter with moderate playing. 3/4 volume with bass knob on remote 25-50% depending on song. Bass knob is turned up just to under clipping light flicker though. Interior lights does dim but not headlights if turned on. Subwoofer cuts off with bass drop test on track 3-5. Saw 240 amp high output alternator on sonix electronic. Maybe 3000 watt xs power battery to play with engine off.
This is my biggest setup so far and I don't feel like messing things up and want to make sure it's running good. And suggestions to improve my setup will be appreciated.
2012 Infiniti qx56
Stock head unit
