Kyle H
So I just got a system for my car, and I am SO lost on how to wire the power for the amps.
1.) I've heard I could run two 4 guage wires from the battery to the amps, one wire for each amp, both with fuses close to the battery.
2.) I've also heard I could run one 4 gauge wire from the battery, with a fuse close to it, to a distribution block, and then run 8 gauge wire from the distro block to each amp.
3.) And then there has been the other people saying to just run an 8 gauge wire from the battery, then crimp another 8 gauge wire onto it, then put the fuses on it, and connect it to the amp. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
#2 Sounds like it's the most plausible, but I just want to make sure that I'm running the right gauge wire. I'm going to be running a PG8.0:1 (600w rms @ 2ohms) and a PG4.0:2 (75w rms x2 @ 4ohms), so would the 4 > 8 guage wire be fine for that?
Thanks!
Kyle
PS-
I got an Elemental Design 13Ov.2, and how do I draw the circle to cut out the sub? are there templates I can print out or do I just need to draw it with a compass? There was no template in the box.
Thanks!
Kyle
PS-
