new amp not powering sub?
is it a dual 4 ohm voice coil?? Could be at an 8 ohm load? I imagine 450 rms at the 4ohms should move it decently. Is it an over rated amp?
either it is a DVC4 wired to 8 ohms or it is a DVC2 wired at 4 ohms, the only way that amp will "wang" the shit outa that sub is if he is running it @2ohms or 1 ohm, the 4 ohm load will tease it. and the 8 ohm wont do a thing. now also need to know if your feeding that amp good clean power. how is it wired up, what gauge wire are your power and grounds?
there you go. you do realize that amp is only going to give two subs 600rms if you load it at 1 ohm. you might get better bass just using the one at 2 ohms = 900 rms. that sub is 500rms-1500pk
im.the.new.hero
im.the.new.hero
Eye of wa
subzero
michigan born
    May 14, 2026
michigan born
    May 14, 2026
