never heard this..
You can do it if you have shield RCA's.
But either way. It is best to run the power/ground wires on the opposite side of your RCA's to AVOID picking up interference.
I know this guy...........he got his stuff installed by some crappy place........they got his RCA and Power cable running together.
He gets random bumps of bass for no reason. When he turns the car off and opens the door ""MMMMMMMMmmmmmmm......." that's what comes out the subs. When he revs the engine, you can hear it in the subs.
What a ******* mess.
He gets random bumps of bass for no reason. When he turns the car off and opens the door ""MMMMMMMMmmmmmmm......." that's what comes out the subs. When he revs the engine' date=' you can hear it in the subs.
What a ******* mess.[/quote']
That has NOTHING to do with RCA's/power wires on the same side.
As mentioned most good RCA's are shielded and it won't be an issue...
Thats from crappy RCAs or a blown Pico fuse if his Headunit is Pioneer.
---------- Post added at 12:12 PM ---------- Previous post was at 12:12 PM ----------
how is it not from the RCA/Power zipped tied together......
Because thats not how those noise issues are created.
Ive had my rcas ran right next to my power wire on several occasions and never had any noise interference. Come to think of it I have my front stage amps ran right next to each other and have no noise whatsoever.
As long as the install is done correctly and you aren't using the most BS rcas ever I wouldn't worry about any noise being picked up.
random bumps out of the subs would be RCA's not tight in amp, input or output bad in amp. Something that is randomly breaking the signal chain.
how about a crappy line out converter that's not groundable?
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
982
This will be an interesting issue to find out. Subscribed!! Are you running components? Ive had some caps blow in Passive xovers and a little...
924
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
There's a few in New Orleans that run those. I think they are the same as the dB Drive A7 series.
14
BoomBoxStereo
@woofergram
BoomBoxStereo
Long Island, NY
mlstrass
    Apr 28, 2024
    Apr 28, 2024
