Never had problems till now .
ernieex3
I had never ran in to a problem hooking up a system in my vehicles but for the first time I need help I got my wife her system for her car I ran the wires put the amp and a 10 inch sub well it works but when it hits pretty good the amp goes to protect mode,well changed the ground wire just to be safe and still shuts off then a replaced the amp and still cuts out my only guess can it be my sub or is it my **** car
Ok check all your connections starting with the power, ground, and remote then check the wire running to the subs. If you don't find any issues move onto the sub (dual or single voice coil?) make sure that it is configured/wired appropriately. If you still find not issues then grab a DMM and check the voltage at the amp (let me know if you need help with this). Make sure your amp is secure/screwed down. Let me know....
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
748
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
801
ernieex3
ernieex3
lovington ,NM
pickup1
    May 12, 2024
Brendon Jenness
    May 11, 2024
