neon lights..
Jordantyler
i have one neon 15" tube under my dash and im thinkin bout purchasin a nother one.. it plugs into my cig litter would i have to run both of them to the fuse box for both of them to work or what should i do??//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I would ditch the cig adapter and wire them to a switch. 12v to one side of the switch, lights to the other side. Then ground the lights. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Extremely easy.
Although, I would wire a relay in line with the remote wire and power the neons that way...and still put a SPST switch inline. The relay just gives you piece of mind that you won't leave the switch open one night and end up with a dead battery.
all you need is a drill to make the hole for the switch, and to make the hole for the screws to hold the tube down, and wire cutters, and a screw driver
5 minute install, its pretty self-explainitory
also.. my friend has a switch with turnin his amp on and off...i was thinkin bout gettin one not sure tho... would that be the same way expect u wire into the remote wire right??
Yes. Sounds like he's wired up a "cop switch" so he can turn off the subwoofer amplifier with a flick of a switch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
There are guides out there (http://www.the12volt.com has one, I believe) for wiring a standard Bosch-type relay to a remote turn on lead. It's pretty simple.
oops , Thanks jack I forgot the relay. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
n00b.
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Jordantyler
Jordantyler
arkansas
TypeRBass
